INVT Launches DA360 Next-Generation High-Performance Servo Drive for Core Workstations in High-End Manufacturing
2026-11-19
Recently, INVT officially launched the DA360 series high-performance AC servo drives, further expanding its motion control portfolio for precision manufacturing industries including semiconductor, lithium battery, precision machine tools, 3C electronics, and packaging.
Today, equipment manufacturers must increase output and maintain consistent quality while also ensuring straightforward commissioning and long-term maintainability. Designed around the real requirements of core workstations in high-end manufacturing, DA360 integrates fast response, high-precision control, and ease of use into a single platform.
DA360 is compatible with DDR, DDL, and other direct drive motor types, and features built-in advanced process algorithms such as gantry synchronization, pressure control, and fly-shot. It flexibly supports rotary servo motors, linear motors, and direct drive applications. In applications such as laser cutting and precision machine tools, accurate coordination between axes directly affects machining quality. DA360 combines gantry synchronization with vibration suppression to help machines maintain precise and stable motion trajectories, while graphical one-click auto-tuning simplifies commissioning and helps engineers translate performance into production capacity faster.
Ease of use continues into daily maintenance. When paired with IMS20B-G6 series motors, DA360 provides a battery-free mechanical multi-turn absolute solution that retains position after power-off and requires no encoder battery replacement throughout the product lifecycle. It also supports encoder configurations up to 26-bit high-precision optical, balancing maintenance-free operation with high accuracy. Built-in fault recording further helps maintenance teams trace abnormal events and reduce downtime.
CE, UL, SEMI F47, and SIL3/PLe functional safety and market access certifications for DA360 are currently under certification. INVT operates a global service network, providing localized support to overseas equipment manufacturers, end users, and distributors.
The launch of DA360 further strengthens INVT's servo portfolio, offering equipment manufacturers a new option for meeting the stringent demands of core workstations in high-end manufacturing, with support throughout the equipment lifecycle.
Explore the INVT DA360 AC Servo Drives  now and discover its capabilities for high-end manufacturing.
Accept
Reject
Cancel
