INVT GD3000 VFD for Electrical Submersible Pump System in Petroleum Industry
2026-07-28
Abstract: The Electrical Submersible Pump (ESP) artificial lift method is widely used in non-flowing high-yield wells, high water-cut wells, and offshore oil fields due to its advantages of simple equipment structure, high efficiency, large discharge capacity, and a high degree of automation. It has become one of the artificial lift methods with stable and high production as well as good economic benefits, serving as a primary means for enhanced oil recovery during the middle and late stages of oilfield development.
Keywords: GD3000, Electrical Submersible Pump (ESP), Oil Submersible Pump
1. Project Background
The Electrical Submersible Pump (ESP) is lowered into the well via tubing, comprising a centrifugal pump and a submersible motor. The motor drives the pump to lift oil to the surface. ESP systems offer a wide range of adjustable flow rates and lift heads, strong adaptability, simple surface process flow, easy management, straightforward automation, and high economic efficiency.
After half a century of development, ESP artificial lift has become crucial equipment in the petroleum industry. Particularly through continuous technical improvements and the application of modern technologies, its adaptability has been significantly enhanced. Technologies suitable for heavy oil, high gas-oil ratio, high temperature, corrosion resistance, and sand control have emerged, contributing substantially to oilfield development.
As major oilfields in China successively enter mid-to-late exploitation stages with increasingly complex geological conditions, Electrical Submersible Pumps will see even broader application.
2. Solution Introduction
2.1 Equipment Working Principle
The Electrical Submersible Pump (ESP) system consists of three main sections: the downhole section, the surface section, and the intermediate section that connects them. The downhole section, which is the primary unit of the ESP, comprises three key components: the multistage centrifugal pump, the protector, and the submersible motor. This section performs the main function of lifting the oil.
The submersible motor, installed at the bottom of the downhole assembly, serves as the power source of the Electric Submersible Pump (ESP). High-voltage electric current from the surface is transmitted to the submersible motor via a power cable. The motor converts electrical energy into mechanical energy, which drives the pump into operation through its rotating shaft.
The protector is mounted above the submersible motor. Its functions are to equalize the internal pressure of the motor and to provide lubrication and sealing. The gas separator is usually installed at the upper end of the protector and the lower end of the multistage centrifugal pump. It is used to separate free gas from the crude oil, thereby improving pump efficiency.
The multistage centrifugal pump consists of stationary and rotating components. The rotating assembly includes a pump shaft onto which a large number of impellers are mounted. When the motor drives the shaft, causing the impellers to rotate at high speed, the fluid within the impellers is forced outward by centrifugal force. This action accelerates the well fluid, imparting kinetic energy to it. The fluid is then guided by the diffuser into the next stage impeller. The energy (or head) is cumulatively increased stage by stage in this manner until a sufficient total head is achieved to lift the well fluid to the surface.
2.2 INVT Solution
Based on actual requirements, the system is designed and developed by the customer. The GD3000 series VFD from INVT is utilized. The frequency control cabinet integrates components including the main circuit breaker, input filter, input reactor, VFD, and output reactor.
2.2.1 Solution Features
  1. Medium-voltage power supply at 1140V; motor voltage at 780V; motor cable distance ranging from 1000 to 3000 meters.
  2. The input side is equipped with a reactor and an input filter, significantly improving the power factor on the grid side of the system.
2.2.2 System Diagram
Block Diagram
2.2.3 Solution Configuration Sheet
NO.NameSelection GuideQuantityRemarks
1VFDGD3000-00-055G-121
3. Product / Solution Advantages
  1. The VFD adopts a new three-level topology, which features low harmonics and reduces damage to the motor.
  2. It offers comprehensive control modes and is compatible with both synchronous and asynchronous motor drive and control.
  3. It features a built-in braking unit, which meets the requirements of energy regeneration applications.
  4. It provides extensive communication interfaces, supporting Ethernet, MODBUS, PROFIBUS DP, among others.
  5. With its compact design, it facilitates customer system integration.
  6. The power supply input features a wide-range grid design with an input voltage of 970 to 1310V, allowing it to adapt to various grid environments.
4. Parameter Logging
NO.IndexFunction code nameString Value
1P00.00Speed Control Mode2:V/F control
2P00.01Channel of running commands2:Communication
3P00.02Communication mode of running commands0:Modbus/Modbus TCP
4P00.03Max. output frequency150
5P00.04Upper limit of running frequency150
6P00.05Lower limit of running frequency0
7P00.06Setting channel of A frequency command8:Modbus/Modbus TCP communication
8P00.07Setting channel of B frequency command1:AI1
9P00.11ACC time 120
10P00.12DEC time 120
11P00.14Carrier frequency2
12P02.00Type of motor 11:Synchronous motor (SM)
13P02.15Rated power of SM37
14P02.16Rated frequency of SM 1150
15P02.17Number of pole pairs of SM 13
16P02.18Rated voltage of SM 1778
17P02.19Rated current of SM30
18P02.20Stator resistance of SM 10.732
19P02.21Direct-axis inductance of SM 17.55
20P02.22Quadrature-axis inductance of SM 17.55
21P02.23Counter-emf of SM 1780
22P05.00HDI input type0:HDIA is high-speed pulse input
23P05.01Function of S16:Coast to stop
24P05.02Function of S29:External fault input
25P05.03Function of S37:Fault reset
26P06.03RO1 output1:In running
27P06.04RO2 output5:VFD fault
28P06.17AO1 output lower limit0:running frequency
29P06.18AO2 output lower limit0:running frequency
30P06.19AO3 output lower limit0:running frequency
31P06.20AO1 output corresponding to upper limit0:running frequency
32P08.37Enabling energy consumption braking1:Dynamic Braking Enable
33P08.38Energy consumption braking threshold voltage1950
34P11.08Pre-alarm selection for VFD/motor OL/UL0x130
35P11.10Overload pre-alarm detection time10
36P11.11Underload pre-alarm detection level0
37P11.12Underload pre-alarm detection time10
38P13.02Pull-in current 130
39P13.03Pull-in current 20
40P13.04Pull-in current switchover frequency50
41P14.00Local communication address1
42P14.01Communication baud rate3:9600BPS
43P14.02Data bit check0:No check(N,8,1)for RTU
5. Field Application Videos and Photos
6. Conclusion
The function of the Electrical Submersible Pump (ESP) system is to achieve high-lift, high-volume fluid lifting. In China, over 40 years have passed since the ESP technology was introduced in 1981, and as a crucial piece of mechanical oil recovery equipment, it has seen widespread application in oilfields. With the advancement of green energy initiatives in China and the extensive development of geothermal wells, coalbed methane wells, and shale gas wells, its potential for broader application is immensely promising.
References
[1] "Goodrive3000 Series Medium-Voltage VFD". Shenzhen INVT Electric Co., Ltd., 2022.
Accept
Reject
Cancel
