What kind of sparks will fly when history meets technology? Deep inside a museum that houses countless cultural heritages, a special INVT "heart" is beating quietly yet powerfully — it not only safeguards the mission of passing down cultural relics in perpetuity, but also escorts the digital life of every treasure with its intelligence and reliability.
1. Safeguarding the Mission That Allows Zero Failures
Efficient Deployment, Smart Management, Green Energy Conservation
Cultural heritage data is irreplaceable once it is lost. This means that the core server room hosting such data must operate without interruption every second of every day. At the same time, valuable digital imaging archives impose extremely stringent requirements on the storage environment, with constant temperature and humidity, cleanliness, and stability as the absolute baseline. Within the limited space of a museum, achieving efficient deployment and intelligent management while fulfilling the social responsibility of green energy conservation has become a systemic challenge.
2. The Solution Path of Smart Integration
Data Center Infrastructure Solution
Facing the multiple challenges of the museum, INVT has designed and deployed an integrated, modular and intelligent data center infrastructure solution, building a solid and reliable digital cornerstone for the museum.
- Power Supply and Distribution System
1 precision power distribution cabinet: It enables centralized and fine-grained power distribution for all IT equipment in the modular data center. Built-in power monitoring modules allow real-time monitoring of the current and power consumption of each distribution branch, providing data support for energy efficiency management.
- Cooling System
2 units of cabinet air conditioners for server rooms:
Maintain the overall ambient temperature and humidity of the server room and battery room.
2 units of 40kW in-row precision air conditioners: Deployed between Modular Data Center, they realize near-end cooling and precise air supply, efficiently dissipate the high heat generated by server cabinets, solve the local hot spot problem, and greatly improve the cooling efficiency.
- Cabinet and Cold Aisle System
15 units of cabinets + double-row micro-module cold aisle containment system
Server cabinets are arranged in two rows, and the cold aisle is fully enclosed through sealing components (top panels, end doors, skylights). This design realizes the isolation of hot and cold airflow to maximize cooling efficiency, serving as a key energy-saving measure.
- Intelligent Monitoring and Management System
* Power and Environmental Monitoring System
It integrates and monitors environmental and safety parameters in the server room, including temperature and humidity, water leakage, smoke, access control, and video surveillance.
* Battery Monitoring System
It conducts online monitoring of the voltage, current, internal resistance and temperature of UPS batteries, gives early warnings of battery degradation risks, and ensures the safety of the backup power supply.
* 43-inch Touch Display Screen
Mounted on the door box of the aisle end door, it centrally and visually displays all the above monitoring data, 3D simulation views, alarm information and PUE value, delivering an excellent human-machine interaction experience.
3. Tangible Customer Value
Safety and Reliability, Remarkable Energy Saving, Intelligent Operation and Maintenance
* Safety and Reliability: The integration of inverter air conditioners and Power and Environmental Monitoring System enables fault early warning, ensuring the continuous online operation of cultural relic data and business systems.
* Remarkable Energy Saving: The closed cold aisle paired with near-end cooling is expected to deliver a 25%-40% energy saving rate, and intelligent power monitoring supports the continuous reduction of electricity costs.
* Intelligent Operation and Maintenance: Unified management via a single dashboard and remote monitoring on mobile terminals lower operation and maintenance difficulty and improve management efficiency.
* Rapid Deployment: Factory prefabrication and on-site assembly shorten the construction period; the modular design supports on-demand expansion to protect the customer's investment.
* Spatial Aesthetics: The compact, tidy and professional layout showcases the modernized and technology-empowered management image of the museum.
This data center has now quietly integrated into the daily operation of China Jiangkou Chenyin Museum. It is not only the technical foundation for storing the digital replicas of cultural heritage, but also a miniature of the intelligent and refined operation of modern museums. Here, the warmth of technology is embodied in every bit of reverence and protection for history.
