INVT Unveils Major IoT Platform Upgrade: Smarter, Faster, More Compatible Than Ever
Listening to users' voices drives product evolution. Over the past six months, INVT R&D team has worked painstakingly, focusing on the four core dimensions of safety, openness, energy efficiency, and convenience, bringing you six major upgrades to the IoT platform! These upgrades are not just additions of functions, but a leap in experience, aiming to make your IoT management "more worry-free, more efficient, and smarter". Next, let's take a look at how these changes will empower your business!
1. VPN Function Upgrade: Remote Debugging Has Never Been So Great!
Engineers' daily routine: Do customers always ask for on-site debugging?
Do they always demand immediate solutions when problems arise?
Remote VPN transmission builds a secure tunnel for remote debugging, allowing engineers to directly access on-site devices remotely and achieve safe and convenient troubleshooting across regions.
Upgrade points:
• Significantly simplified configuration process: Establish transmission in 3 steps.
• Remarkable speed improvement: Establish a channel in 30 seconds with a success rate of over 95%.
• Higher connection stability: No disconnection for 30 minutes, guaranteed by dedicated servers/bandwidth.
Ensure the safety of remote operation and maintenance, and make data transmission as solid as a rock, allowing you to connect every device with confidence.
VPN Remote Debugging:
2. Devices Support Multiple Brands and Protocols: Break Ecological Barriers to Achieve Interconnection of Everything
Engineers' daily routine: Are different customers' brand devices mixed? Are the protocols different? Are different devices difficult to uniformly access and manage? Is it difficult to transform old devices?
Upgrade points:
• Newly support protocols of more than ten common brand controller products on the market; communication can be established by selecting brand and model as needed.
• Provide more flexible protocol parsing tools or configuration interfaces.
Say goodbye to "information islands", easily access various existing and new devices, and truly realize unified management and data integration of devices!
Illustration:
3. Algorithm Optimization of Air Compressor Control System: Energy Saving and Efficiency Improvement Are Visible
Daily routine of gas station management: High energy consumption of air compressor stations? Low coordination efficiency of multiple devices?
Large pressure fluctuations? Relying on manual experience for adjustment?
Upgrade points:
• Optimization of equipment control algorithms, better number control strategies, minimum number of starting units, adjustment of priority mechanisms, etc., and iterative optimization of core control algorithms.
• Possible effects: The average energy-saving effect is increased by 5%, and the pressure stability is increased by 7%.
Driven by intelligent algorithms, it realizes the optimal cooperative operation of multiple air compressors, significantly reduces energy consumption costs, improves gas supply stability, and the energy-saving benefits are immediate!
Illustration:
4. Addition of Web Version for Remote VNC Function: Anytime, Anywhere, No Installation Required
Salesmen's daily routine: Only show pictures to customers, and need to go to the site to see real cases? Need to install a specific client for remote desktop?
Device administrators' daily routine: Need to configure and collect all device parameters on each site? Is it inconvenient for operation and maintenance personnel to handle emergencies outside?
Upgrade points:
• In addition to the mobile APP, a Web browser-based VNC remote desktop access function is added.
• No need to install additional software, just log in to the problematic IoT platform through the browser.
Break through terminal restrictions, securely access the device desktop anytime and anywhere through the browser, respond to emergencies faster, and greatly improve operation and maintenance efficiency!
Illustration:
5. IoT Platform Equipped with AI, Are You Looking Forward to It?
INVT IoT platform will soon launch "Xiaoying Intelligent Customer Service", which is equipped with DeepSeek's AI algorithm. She can answer many questions. You can ask her like this:
Functional inquiries: What can you do? What questions can you answer?
Introduce the functions of GD5000xxx; What are the common faults of GD5000?
Technical support inquiries: What is the solution to the alarm code xxx?
What debugging steps are required for the function code (xxx)? How to deal with the alarm code xxx of GD5000?
Compound reasoning inquiries: When the GD5000 high-voltage frequency converter operates with xxx, if xxx occurs, how to solve it through master-slave function debugging? Please combine with the control board parameter configuration instructions.
Analyze the hardware modules and software configuration points that may be involved in the master station reporting slave response timeout. Compare the differences between xxx and xxx of GD5000.
"Ask Whatever You Think" inquiries: Memory test "How did you use the function you mentioned last time?" "What else is there for the xxx function of the device I just mentioned?" "What question did I just ask?"
Long questions: Multi-demand compound questions with more than 200 words.
It is expected to meet you in September. We are really looking forward to it. If you have other expectations for "Xiaoying", you can tell us in the message area!
"Upgrades are ready, and empowerment is in time!" Log in to your platform now to experience the changes brought by these innovations!
We look forward to hearing your feedback and will continue to work with you to drive your business towards a future of higher efficiency, lower cost and stronger competitiveness with innovative IoT technology!
New users: Register now to experience and start an efficient and intelligent IoT management journey! [Registration link attached]
Old users: Your platform has been automatically/soon upgraded. Welcome to log in and experience the new functions! If you have any questions, please feel free to contact your customer manager or check the help document.
More Featured News
Contact INVT
Industrial Automation
Network Power
PV & ESS
e-Mobility
