INVT at SPS 2026: Solutions for Energy Storage, Precision Manufacturing and Flexible Control
2026-11-10
INVT will exhibit at SPS 2026 on November 24–26 in Nuremberg, Germany, at Hall 1, Booth 1-324. Under the theme “GREEN · RELIABLE · SMART,” INVT will showcase solutions that address key engineering challenges in energy storage, precision manufacturing and industrial connectivity.
GREEN: Supporting Renewable Energy Integration
Power fluctuations create energy regulation challenges for renewable energy plants and microgrids. Addressing these demands requires coordinated energy storage, power conversion and control.
INVT’s smart flywheel energy storage solution brings these functions together with cooling and voltage transformation systems to support power regulation. Its applications also extend to critical loads and grid-side regulation.
RELIABLE: Precision at Higher Production Speeds
Increasing production speed without compromising consistency is a key challenge in capacitor winding. At higher operating speeds, the equipment must maintain precise multi-axis synchronization and accurate pin welding positioning.
At the INVT booth, visitors can learn how the TP2000 motion controller and DA180A servo drives address this challenge through coordinated multi-axis control and precise positioning. The solution offers a starting point for discussions on balancing production speed, accuracy and maintenance requirements.
Visitors can also explore five-axis control, high-speed circulating slurry mixing, and electrode roll pressing and slitting solutions, and discuss how INVT addresses different process requirements across 3C and lithium battery manufacturing.
SMART: Flexible Industrial Connectivity
Complex cable routes can delay equipment installation. Changes to production lines often require rewiring and additional commissioning. These challenges make it important for equipment manufacturers and system integrators to maintain reliable communication while accommodating more flexible layouts.
At the INVT booth, the team will present its industrial wireless control solution, which combines WIA-FA technology with industrial interfaces including EtherCAT and PROFINET. The solution supports demanding communication timing requirements and reduces cabling, giving users greater flexibility in equipment deployment and layout changes.
PLC and remote I/O solutions will also be on display, allowing visitors to discuss signal acquisition, equipment integration and wireless connectivity with the team.
INVT welcomes equipment manufacturers, system integrators and industry users to Hall 1, Booth 1-324 to discuss application requirements and explore solutions for equipment development and system upgrades.
Accept
Reject
Cancel
