INVT EC600 Intelligent Integrated Panel Solution for Home & Commercial Buildings in India
Release time:2025-12-31
Click amount: 3691
Introduction for Elevator
Traction elevators are driven by alternating (AC) or direct current (DC) electric motors. The friction between the hoist steel ropes and the sheave is used in traction elevators to move the car. Traction elevators use a counterweight to offset the occupants and elevator cab's weights so that the electric motor doesn’t have to move as much, making traction elevators much more energy and power efficient than hydraulic elevators. Traction elevators have remained relevant in the building industry. The uniqueness of traction elevators makes them stand out, especially for mid to high-rise buildings, making them the commonest choice.
Components of Traction Elevator with Machine Room
Customer Requirement
  • The site was a commercial building. Customer required a compact, good-looking panel with very low mechanical sound.
  • Easy installation with minimal complications and fewer wires.
  • The panel should provide a smooth riding experience with no noise at starting and stopping.
  • Controller must have all safety features based on EN81 safety standards.
* Challenges
  • Limited installation space provided by the customer.
  • Low magnetic contactor on/off sound.
  • Gearless machine requires very high starting torque.
  • Need zero speed load companion feature to overcome starting jerk.
  • Drive should support high ambient temperature while maintaining stable performance.
INVT Solution
INVT provided the EC600 Intelligent Integrated Panel Solution, a next-generation dedicated elevator solution for home and commercial buildings.
* Key feature:
  • Noise limited to 50dB for low electrical sound.
  • Standard STO (SIL3), electronic star shorting for PM motor.
  • Standard C3 filtering, optional built-in C2 filter.
  • Electronic star sealing.
  • OTA technology.
  • Support for closed-loop control mode, geared & PM motors, static & rotational motor tuning.
  • Built-in incremental PG card for 5V, 12V, and 24V selectable; optional encoder types: SIN/COS, ENDAT, SSI.
  • Direct landing; advanced S-curve algorithm improves comfort during acceleration, deceleration, and stop.
  • Starting torque compensation to prevent rollback at startup; 200% for 10s overload capacity.
* Configuration of EC600 Elevator
- Installation of EC600 on lift has below detail:
ParameterValue
Lift speed0.700   m/s
Capacity408   kg
Floors5   floors
Power supply3-phase   380V
Motor typeSynchronous
Rated power3   kW
Tab 1 Lift information
Fig: EC600 Control Panel
Fig: Motor with nameplate
* EC600 Electrical Configuration
Based on lift configuration and required functions, the electrical solution is as follows. Considering higher ambient temperature, one grade higher of machine rating was selected.
ItemModelQty
EC600 InverterEC600-MR2-7R5-4-B-SU1
Gearless MotorSHARP1
EncoderHEIDENHAIN   SinCos1
Brake Resistor122Ω   / 1200W1
Configuration List
Customer Benefits
  • Smooth and silent elevator operation during running.
  • Quick installation and commissioning, saving time.
  • Energy-efficient compared to geared machines.
  • Electronic star sealing adds extra safety.
Conclusion
The successful installation of the INVT closed-loop system with a 1387 SIN/COS encoder provided a jerk-free, smooth-running experience with high system stability. This project demonstrates INVT’s high-efficiency, advanced technology system capable of handling all types of challenges with energy-efficient, low-cost, and time-saving solutions.
