INVT iTalent Integrated Data Center Solution for Computing Power Center in Zhongguancun Science City
Release time:2026-04-16
Click amount: 2155
When data streams at a rate of billions per second rush through, what kind of infrastructure can shoulder the heavy responsibility of a national computing power center?
In the latest 600-square-meter common technology platform for AI enterprise services that has been newly established in the Zhongguancun Science City of Beijing, our answer is - iTalent "Double-row Cold Channel Integrated Data Center Solution". INVT collaborates with Century Internet, adhering to extremely high reliability standards, to build a solid physical foundation for this "digital brain".
Project background
The common technology platform and computing power center provided by this artificial intelligence enterprise serves high-load computing tasks such as artificial intelligence and big data analysis; it has strict requirements for the stability of infrastructure, heat dissipation efficiency and space utilization. Customers need a highly integrated and intelligent management solution to cope with the increasing demand for computing power.
On-site plan:The computer room is equipped with 26 modular exhibition cabinets, 7 row air conditioners, 2 precision row cabinets, 17 IT cabinets, a 75-inch large screen, forming a 1800mm-wide hot aisle.
Highlights of INVT Solution
01 High-density computing power carrying capacity
Modular layout, high-density cabinet deployment, provide sufficient computing power carrying space for AI training, big data analysis and other businesses, meeting the continuous growing computing power demands of customers.
02 High-integration design, saving space
The iTalent integrated data center adopts a modular architecture, integrating systems such as cabinets, power distribution, cooling, and monitoring. This significantly enhances the space utilization rate and perfectly suits the limited space requirements of customers.
03 Efficient cooling, precise environmental control
Through the intelligent temperature control system and precise air flow organization design, the hot aisle is precisely temperature-controlled, and the PUE value is significantly optimized. This helps customers reduce operating costs and implement the concept of green data centers.
04 Intelligent monitoring, worry-free operation and maintenance
Equipped with a remote management system, the 75-inch digital screen centrally displays 3D dynamic environmental monitoring data. It supports real-time visualization of temperature fields and power loads, significantly enhancing the speed of fault response.
Customer Benefits
* Business Continuity: High availability design ensures uninterrupted AI training and big data analysis operations 24/7.
* Stable and Reliable: Dual power supply + intelligent power distribution system, zero interruption for critical business, with annual failures approaching an extremely low value.
* Flexible Expansion: Modular structure supports future computing power expansion, meeting customers' long-term development needs.
When the scientists in the Science City of Zhongguancun use computing power to crack genetic codes and train AI models, our dual-row iTalent system is safeguarding these operations that change the world with highly secure and reliable outstanding performance. This is not only another successful case, but also our answer to the propositions of the "New Infrastructure" era. Your next strategic data center project deserves the same level of professional guarantee.
