INVT Modular UPS Solution Powers Government Big Data Center in Qinghai China
Release time:2026-01-14
Click amount: 1926
Discipline Inspection Big Data Center is the “brain” of intelligent discipline inspection, and the efficient use of information technology is an innovative initiative to strengthen discipline and anti-corruption propaganda. The data center infrastructure is the key to carry the big data supervision platform, and the reliable power supply and distribution system bears the heavy responsibility of stable operation of the data center system. In order to meet the security requirements of the big data monitoring platform, the overall construction program needs to be more secure, reliable and able to provide 24-hour efficient and uninterrupted service.
Recently, with rich practical experience in the power supply industry, INVT successfully won the bid for the power supply project of China Qinghai Provincial Discipline Inspection Commission, providing reliable power protection for the Integrity Education Center in Haidong City, Qinghai Province, and contributing to the construction of beautiful Qinghai.
According to the customer's requirements, INVT power supply tailor-made a set of power system solution for the center, which adopts RM series 25~200kVA rack-mounted modular UPS, 3P-input/3P-output, double-conversion on-line work, N+X parallel redundancy technology, and high-density power module design inside the module, which not only ensures the compactness of the layout, makes full use of the unit area space, but also increases the reliability and stability of the whole UPS, can also meet the demand for capacity expansion at a later stage.
Solution Advantages
On-demand Configuration, Convenient Maintenance: Adopting high-density power module unit, on-demand configuration of power capacity, modularized unit design to achieve on-line hot-swappable, more convenient maintenance.
Rack mounting, flexible: UPS directly embedded in the standard 19-inch cabinet installation or direct floor mounting, the installation mode can be flexibly selected according to the site conditions;
Easy to parallel cabinets, convenient and quick: no need to consider the UPS host and the cabinet between the parallel cabinets, the site and the cabinet is more convenient and quick;
Layout and unified management: UPS adopts the layout of the row, which is convenient for the centralized and unified management of the equipment;
In-row cooling source, green and efficient: the use of cold pool cooling source for UPS nearby cooling, improve the utilization rate and efficiency of refrigeration equipment, reduce equipment CAPEX costs.
INVT always adheres to the market-oriented and customer-centered business policy, and makes every effort to provide value-for-money products and services to make customers more competitive. In the micro-module data center product line, INVT practiced the concept of green development and launched three different application solutions for micro, small and medium-large scale respectively, namely ISmart, IWit and iTalent. Each application solution adopts standardized and modularized design from sub-systems to the overall architecture, and at the same time jointly applies energy-saving technologies such as closed hot and cold channels, modular UPS, in-row cooling, natural cooling interconnection, and so on, so as to realize green, energy-saving, and high-efficiency operation. At this opportune moment of the development of the intelligent data center construction industry, we are striving to realize our corporate vision of “becoming a globally leading and respected provider of products and services in the fields of industrial automation and energy and power”.
